Algorithm
Navyadubey
Re: Algorithm
Post by Navyadubey »
Dear Sir,
Thank you, I found different GUIs of CC, what if I want to make a new GUI how to link that GUI with the project features.
And an error flash is there while building the project in QT " error: No rule to make target 'all'. Stop. "
I am also very confused regarding the versions of QT creator and Visual Studio.
It will be really helpful if you could tell me which version of the software is compatible & appropriate to use.
Re: Algorithm
UI files (that you can create with Qt Designer) are automatically added to the project when you run CMake (when you click on 'Generate') if they are in the 'ui_templates' folder.
And for your Qt Creator issue, I can't tell as I don't use it. I just know that several users use it successfully.
Navyadubey
Re: Algorithm
Dear Sir,
I am unable to view the icons in some inside dialogue boxes like rasterize dialogue box and translation and rotation dialogue box and I can only find the icons which are there in mainwindow, So could you please tell me where to locate all these icons.
Re: Algorithm
Most icons are in the same folder and they are listed in a Qt 'resource' file (.qrc) that is referenced by the dialogs. Qt Designer can help you find everything easily.
The plugins have generally their own icons and resource file.
