(Load) Cant`t guess file format: unhandled file extension `rdbx`
hha116
Post by hha116 »
I have got an pointcloud from a groundbased lidar, that is in a RDBX format. When I try to uppload the file I get this message:
I`m using Windows 10 enterprise, 64-bit operating system. What can i do?
Re: (Load) Cant`t guess file format: unhandled file extension `rdbx`
Which version of CloudCompare are you using? And can you check if you have a 'rdblib.dll' file next to CloudCompare's executable?
hha116
Post by hha116 »
I have the cloudcompare v.2.7.0 (64 bit). But can not find the `rdblib.dll`. Should it be inside the folder of CC?
Nope, in this case you just have to update to a more recent version ;). The 2.9 or 2.10.alpha.
Rdbx was not supported in the 2.7
hha116
Post by hha116 »
Thanks, that worked well.
hha116
Post by hha116 »
One more question:
I will use the point cloud (rdbx file) for structural analyzes in coltop3d afterwards, were I need the format ascii text file (xyz intensity or rgb columns). When saving the pointcloud in CC I can choose the format: ASCII cloud (*.txt *. asc*. neu*. xyz*. pts*.csv).
After saving I only get an txt.file, but is this txt.file containing the other formats as well? or do I have to convert the file another way to get the xyz or rgb?
Håvard
Not sure to understand: the txt file on output should contain X, Y, Z and R, G, B columns if the cloud has colors). Or do you want to know if you can change the extension of the file ? (if yes, then yes you can)
hha116
Post by hha116 »
Ok, thanks.
hha116
Post by hha116 »
One last question:
After subsampling the pointcloud in CC, the coordinates is negative? Can this be a result of subsampling ?
Nope, the 'subsample' tool only selects some particular points of the cloud, it doesn't displace them.
