Cannot load plugin qPCL
Re: Cannot load plugin qPCL
Interesting side effect. I'll look in this direction then (before compiling qRansac, was qPCL the only plugin?)
Yes it was.
By the way, your software is terrific, thank you!
Okay I fixed the issue (the Plugins menu was not enabled as long as a plugin with only one method was not loaded (and as the qPCL as several of them, the Plugins menu was staying disabled).
Thanks for the feedback.
P.S.: I've pushed the modification on the 'CleanMeshCutter' branch for now.
olivierl wrote: ↑Thu Mar 05, 2015 10:27 am Hi Daniel,
Thank you for your answer, it was very helpful. I could start cloudcompare with the pcl plugin using prebuilt pcl. I had to edit the PATH variable for that and add: "D:\DEV\PCL\3rdParty\VTK\bin;D:\DEV\CloudCompare\install\CloudCompare_debug;D:\DEV\PCL\bin;D:\DEV\Qt\5.2.1\msvc2012_64_opengl\bin".
It's a bit dirty, because I needed to compile VTK to get it detected by cloudcompare cmake (VTK of PCL-pre-built was not detected) but eventually I use VTK of PCL-prebuilt.
So, when I launch cloudcompare compiled with pcl plugin, I can see in the console the following messages:Meaning that the plugins are loaded.Code: Select all
[11:13:02] Plugins lookup dir.: D:/DEV/CloudCompare/install/CloudCompare_debug/plugins [11:13:02] Found new plugin: 'QCSV_MATRIX_IO_PLUGINd.dll' [11:13:02] plugin name: [CSV Matrix I/O filter] [11:13:02] file extension: CSV [11:13:02] Found new plugin: 'QPCL_IO_PLUGINd.dll' [11:13:02] plugin name: [PCL I/O filter] [11:13:02] file extension: PCD [11:13:02] Found new plugin: 'QPCL_PLUGINd.dll' [11:13:02] plugin name: [PCL wrapper]
Similarly, in menu Help>About Plugins.., QCSV, QPCL_IO and QPCL plugins are detected.
But... the plugin menu is disabled, and I can not access to the PCL plugin
Any idea?
Thanks,
Olivier
PS: I am trying to postpone PCL compilation on windows as it seems many people have difficulties with that.
Hello, Olivier,
I have the same problem taht " QPCL_IO_PLUGINd.dll does not seem to be a valid plugin (Cannot load library C:\CloudCompare\CloudCompareProjects\CloudCompare_debug\plugins\QPCL_IO_PLUGINd.dll: Le module spécifié est introuvable.)"
It seems that you have fixed this problem, but I don't understand how you did it, can you explain more to me?
