I'm having trouble with shapefiles exported from v2.10.2 as they will not load up in ArcGIS. The export from CC seems to work fine and is the same as it has always been in previous versions, but Arc gives me an error saying that it cannot draw the selected data.
I took my data and re-exported the shapefile in an older CC version (2.9) that I have on a different computer and the shapefile worked fine in Arc. I'm pretty sure it's not a data issue as I've been working with these pointclouds for a couple of years.
Any help would be greatly appreciated!
Exported shapefile (CC v2.10.2) will not load in ArcGIS
Re: Exported shapefile (CC v2.10.2) will not load in ArcGIS
Yes this issue has been declared recently! I am currently investigating it. It would be good if someone can declare the 'issue' on github by the way ;)
Ok the bug is fixed! I updated the 2.11.alpha (non-stereo) version online.
Otherwise, I believe it is possible with QGIS to remove the SHX file next to the SHP file and make QGIS recreate it properly (it was the culprit, this file was malformed).
That's great, thanks Daniel. Sorry I didn't see it had been declared already, I did have a look around. In future I'll put any issues on github :-)
