I'm experiencing pretty regular crashes when performing SOR on a small (4000 point) point cloud. On many it doesn't go beyond a certain percentage before freezing. Do you have any idea why this is happening & how to solve/avoid the issue? Using v2.10.2
Crashing during SOR
Re: Crashing during SOR
It doesn't crash on my side, and not with any cloud I have. Can you maybe share the cloud and the parameters you are using? (admin [at] cloudcompare.org)
Dear Daniel,
I appear to have a similar problem - SOR filter keeps going into a total freeze (no response / stopped working) on some poinclouds from TLS. I am processing many clouds of the same origin and that have been processed in the same way using the same settings, but only some lead to a crash. Other clouds are even bigger and have no problem. I am emailing you one of the pointclouds and would be very thankful if you could look into it.
Thank you
Thank you
I believe the solution was to move to the latest beta version?
