My compiled environment:
Win10 x64
Inte|(R) Core(TM) 17-9700 CPU @ 3.00GHz (8 CPUs), ~3.0GHz
DirectX 12
Intel(R) UHD Graphics 630
cmake3.20.5
qt5.9.1
vs2017 x64
cloudcompare2.11.3
1. Create a folder in the d drive as shown in the figure
2. Select this in cmake
Click on configure and generate
3. Find the sln file in the build folder and open it with vs2017
Right click all_build and click regenerate
Right-click ALL_BUILD, click Regenerate
4. I get this in the file
Double-click to open and display
In windows event viewer, it shows this.
can you help me
Win64 can't open cc after compiling, it shows 0xc0000142
Re: Win64 can't open cc after compiling, it shows 0xc0000142
the last picture
- Picture7.png (45.46 KiB) Viewed 65062 times
But I compiled cloudcompare2.10.2 in the same way and it worked.
Today I was able to compile and run successfully with qt5.12.5.
But I am using qt5.9.1 in linux, I need to port the program to windows, in order to avoid unnecessary trouble, I still hope I can compile with qt5.9.1 successfully.............
I tested it today
cc2.10.3 qt5.9.1 works
cc2.11.3 qt5.9.1 not work
cc2.11.3 qt5.9.2 works
I think it's because cc2.11.3 and qt5.9.1 are in conflict.
But I don't know exactly what's wrong.
Please tell me why :(
thanks~
thanks~
Frankly, I have no idea...
I use cc2.11.3 qt5.9 not work and have the same issue like yours.
Have you solved the issue please?
no ,
i use cc2.11.3 with qt5.9.2 .
