Hello
I'm a student in Oceanography, I work on complexity of substrate in marine bottom. For this use I generate 3D model with photogrammétrics technic.
And I measure my data on this model with cloud compare.
One of the data that I want to measure is the slope of the model. Models are rectangular and I want the slope on several section of the width.
Does someone know How it is possible ?
thank you
And sorry for my bad English
Measure Slope
Re: Measure Slope
Basiquely, I want to know the mean slope between this two point of my models
- point and slope
- Capture d’écran (11).png (189.72 KiB) Viewed 6373 times
Re: Measure Slope
In CloudCompare, there's basically two ways of computing the 'slope' (as the 'dip' and 'dip direction' values):
- either you fit a plane on a subset of points (at least 3, but in your case you can try to fit a plane on your whole cloud). You'll get the corresponding plane normal and also the equivalent dip and dip directions (either in the Console or in the plane properties dialog).
- otherwise if you have normal vectors expressed for each point of your cloud, you can convert them to 'dip and dip direction' values (Edit > Normals > Convert to > Dip / dip direction SF). If you don't have the normals, you can compute them with 'Edit > Normals > Compute' (see http://www.cloudcompare.org/doc/wiki/in ... %5CCompute). But to get the slope between your two extreme points, you would have to use a huge radius, and it would be a bit overkill. I think the plane fitting option should work better.
Re: Measure Slope
Thank you daniel
The plane fitting option is easier and it work perfectly...
But I'm just asking how it work.
Witch point i use for determinate the slope orientation ( dip direction)
Re: Measure Slope
Well, the plane fitting option uses all the points. You can segment the cloud (with the scissors tool) if you want to be more selective.
Re: Measure Slope
I have a doubt. Bow to measure angle of slope in CC? Like I can measure dip/dip dorection, but I need this for determining scanline or planar of slope, to use in dips (orientate the traverses). So if there any ideas, please share with me.
Re: Measure Slope
Not sure, but you may be able to play with planes (primitives)? You can ether match planes on subsets of points, or create planes manually. Then you can select 2 planes and use 'Edit > Plane > Compare'. Among other things, you'll see the angle between the 2 planes...
