I have generated the CC files with Cmake 3.6.1 & Qt 5.7 and built up the solution (INSTALL file) on MSVS 14(Update 3 2015)
I am getting these errors. What am I doing wrong?
Error list 1/2
Error list 2/2
VS output
Copilation errors with MSVS 14(Update 3 2015)
Re: Copilation errors with MSVS 14(Update 3 2015)
What CMAKE_INSTALL directory have you set? Can you show us your CMake configuration maybe?
And I'm not sure that Qt 5.7 is supported yet (some people have reported issues on Linux at least).
1] The Camke config is same for Qt5.7 AND Qt5.6.1 (except QT5_ROOT_PATH)
2] I tried Qt version 5.6.1 and the number of errors have increased.
3] It is mentioned here (https://github.com/cloudcompare/trunk/b ... ms_eng.txt)
that Qt must be compiled for 64 bits version on Windows. But I am using Qt Offline Installers from https://www.qt.io/download-open-source/#section-2 (not sure that is okay)
The errors you get with Qt 5.6 are known (see viewtopic.php?t=1835). They are due to Visual 2015. When you apply the patch mentioned in the other thread, do you manage to compile the 'INSTALL' project?
P.S.: your INSTALL prefix is a bit weird (it should be a simple directory like 'D:/CCProjects"). But I don't think it is the cause of your first issue.
