changing default units
It is difficult to interpret the default units and would like to shift them to read in standard feet measurements and visualize them on screen display and any output.
Re: changing default units
Well, there are no 'default units' in CloudCompare. CC displays the values / coordinates / distances / etc. in the same units as the one present in the file you have loaded.
But if you want to change them, you can use the 'Edit > Multiply / scale' method to convert the coordinates to something else (of course you'll need to know what are the original coordinates... but only you can guess it as it's not written in the file).
