View from a plane
pmnrebelo
Re: View from a plane
Post by pmnrebelo »
Thanks a lot for your reply!
My last question it's how can i scale the ortophoto, i read this topic viewtopic.php?t=1428 but i got confused...
If you can help me...
Regards
Can you be more precise? What kind of scale do you want to apply?
pmnrebelo
Post by pmnrebelo »
I need be sure that have 5mm and it was confirmed! Thank you for the help! I measure on paint and problem solved !
Can you say me if i can put the center of my mesh on the center of my plane?
Regards
Well, you'll probably have to apply a translation either manually (with the 'Edit > Translate/rotate' tool) or numerically (with the 'Edit > Apply transformation' tool).
A last option is to use 'Tools > Registration > Match bounding-box centers'... which does exactly what you are describing (even though I'm not sure this is what you meant ;) ).
pmnrebelo
Post by pmnrebelo »
Ok it's this!!!
I'm very grateful for your impressive help. Your support was amazing!!
I will use the CC now for my jobs!
Regards,
Pedro Rebelo
