Fine adjust reference/anchor/pivot point
Posted: Wed Jan 20, 2016 10:11 pm
Hi Daniel
I have been thinking about, if it is possible in CloudCompare, to fineadjust the reference/anchor/pivot point. If it is possible, then I would like to know how.
I am using point clouds, to create the landscape base, for racetracks made for Assetto Corsa.
At the moment 2 tracks, but that could become more. There is a couple of other games, I consider converting to.
I am learning Blender and have decided that, I will cover the full density mesh, with a low poly one.
The result are better than what I got, with a subsampled cloud before meshing.
Working with the full density mesh slows the pc down.
I have decided to cut the mesh, into smaller chunks before exporting. This is much easier done, in CloudCompare than in Blender.
My one issue, is the anchor point.
In the time I have worked with this, I have gotten the anchor point moved, from about 78 km away from the model, to roughly 500 meters away.
I would like to put the anchor point, at the center of the model.
I may be wrong, but my thinking is, that it should make it easier, to reassemble the chunks later.
Is it possible to do this, in Cloudcompare and if, how do you do it?
My base is a LAZ cloud, exported as an STL mesh with CloudCompare. I do the cutting with the reimported STL file.
I know I can do this in Blender, but I would prefer to do it in CloudCompare, rather than going back and forth.
If it is helpful I can upload the base file to dropbox. It is 9 MB.
Active Scaler Field is Classification and Filter by Value is 2 to 2
The progress of my Nisseringen track, can be seen here:
http://assettocorsamods.net/threads/nis ... scape.420/
I hope you will have a great day.
Greetings from Denmark
Dan Nielsen
Dan Nielsen
