qCANUPO export the multi-scale dimensionality metrics for each point
Posted: Mon Mar 07, 2016 6:12 pm
Hi, I'm trying to combine some scalar fields of points and the multi-scale dimensionality metrics from CANUPO together for classification or unsupervised clustering of points. Is there anyway I can export the multi-scale metrics from qCANUPO in CloudCompare so that I can use them along with the other scalar fields in a preferred clustering algorithm? I tried the original CANUPO program from http://nicolas.brodu.net/en/recherche/canupo/ to export it. But I found that the speed of that program is somehow much slower than the qCANUPO implementation in the CloudCompare. Not sure if I did something wrong with the original program. I did use the same amount of core points for metric calculation.
If possible, can I borrow the source code of the plugin qCANUPO and add export function or wrap the qCANUPO implementation into a standardalone but faster CANUPO. I checked the repo of CloucCompare on github but didn't find the source code of qCANUPO.
Have you got any thought on this? Thanks for any comment or suggestion.
Zhan.
Zhan.
