☑ qCSF compile (make) error on Ubuntu 16.04
Posted: Fri Jul 15, 2016 9:35 pm
after a completed compilation without this plugin, I ended up with an error when trying to compile while enabling INSTALL_QCSF_PLUGIN in cmake-gui.
Here is the last lines of the 'make' process :
The strange characters here come as they also are in my terminal stdout. It's not a copy/paste error or whatever.
I'm running Ubuntu 16.04, kernel : 4.4.0-28-generic, Qt 5.5.1 (and libLAS 1.8.0)
Thanks !
Regards.
ps: oops, do not hesitate to move the thread to the developer section if needed.
[ 56%] Generating qrc_qCSF.cpp
[ 56%] Generating ui_CSFDlg.h
Scanning dependencies of target QCSF_PLUGIN
[ 56%] Building CXX object plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/Cloud2CloudDist.cpp.o
In file included from /home/username/Downloads/CloudCompare/trunk/plugins/qCSF/Cloth.h:28:0,
from /home/username/Downloads/CloudCompare/trunk/plugins/qCSF/Cloud2CloudDist.h:4,
from /home/username/Downloads/CloudCompare/trunk/plugins/qCSF/Cloud2CloudDist.cpp:1:
/home/username/Downloads/CloudCompare/trunk/plugins/qCSF/Particle.h:35:2: error: ‘size_t’ does not name a type
size_t nearestPointIndex;//��Ӧ��lidar�����ٽ��������� index nearest lidar point
plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/build.make:75: recipe for target 'plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/Cloud2CloudDist.cpp.o' failed
make[2]: *** [plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/Cloud2CloudDist.cpp.o] Error 1
CMakeFiles/Makefile2:1542: recipe for target 'plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/all' failed
make[1]: *** [plugins/qCSF/CMakeFiles/QCSF_PLUGIN.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 56%] Building CXX object plugins/qPCL/PclIO/CMakeFiles/QPCL_IO_PLUGIN.dir/QPCL_IO_PLUGIN_automoc.cpp.o
[ 56%] Built target QPCL_PLUGIN
[ 57%] Linking CXX shared library libQPCL_IO_PLUGIN.so
[ 57%] Built target QPCL_IO_PLUGIN
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
Thanks !
Regards.
