personnal scipt
williamP
personnal scipt
Post by williamP »
I want to know if it possible to write a script which use some differents applications or module of CC in order to automate post-processing of a points clouds and compar them ?
If it is possible to write a personnal script do you know the language I have to use ?
thanks you for your answers :)
Re: personnal scipt
Well, you have the command line mode: http://www.cloudcompare.org/doc/wiki/in ... _line_mode
Otherwise you can of course produce your own (C++) code using the CC_CORE_LIB library (and optionally the qCC_db and qCC_io ones).
williamP
Re: personnal scipt
Post by williamP »
thanks you Daniel !
