Data format for cloud point
ziarehmann
Post by ziarehmann »
I am very new user of cloudcompare, as a matter of fact just installed the software. I am scanning a suface using Panasonic distance sensor (Z cordinate) mounted on two linear actuators with encoder (encoder values x,y). I am getting this information (x,y,z coordinates 10000 points) in CSV format.
The basic question in which format can i import these values in cloud compare? Do i need any other file format? or any other conversion software?
Hope to hear from your side soon.
Re: Data format for cloud point
You should be able to load it directly from the CSV file (as an 'ASCII/text' format).
ziarehmann
Thanks for the reply. My bad i looked into it and everything worked fine with CSV and text data.
Regards!
Zia
