-VOLUME command line argument not working correctly
Posted: Tue Oct 24, 2017 12:55 pm
I'm trying the new command line feature to calculate volume among two point clouds (added in beta version 2.9).
I'm launching it through the following command line command:
cloudcompare.CloudCompare -SILENT -o ./pc_1.las -o ./pc_2.las -VOLUME -GRID_STEP 1.0
After the 'Process Finished' text a "Segmentation fault (core dumped)" error appears and the calculation in the Report text file is not the same obtained using the graphical user interface (through Tools-> Volume -> Compute 2.5D Volume); it is wrong because I have tried with simple las files for which I already know which could be the result (with gui the result is correct).
What could be the problem?
Cheers,
Francesco
Cheers,
Francesco
