Is there a way to start CloudCompare on a server?
Posted: Fri Aug 03, 2018 11:09 am
by swiss_knight
I'm wondering if, for example for CPU power reasons, one can start CloudCompare on a server ?
I have a local Linux server on which I usually connect through SSH.
I have installed CloudCompare from sources.
But when I try to start it in the so called "command line mode" (I feel it doesn't seem to be purely a command line mode...) I encountered this issue:
QXcbConnection: Could not connect to display
Aborted (core dumped)
Any workaround, for example to make CC thinks there is a display even if there isn't ?
Thanks.
