How to capture the images and make figures?
Kwanmok
Post by Kwanmok »
I am trying to make figures based on the results in the screen.
Is there an option where you can customize the scale bars and capture images of the screen. Or do you simply use the capture function on the keyboard or different software?
Kwan
Oiz
Re: How to capture the images and make figures?
Post by Oiz »
If you're talking about capturing what you see in the 3d view, have you tried using the tool "Render to File" under the "Display" section of the menu bar?
Kwanmok
Post by Kwanmok »
Great thanks. I have tried all other functions but never thought 'render to file' would do this work.
Oiz
Post by Oiz »
Out of pure curiosity, as I often work as a UX/UI designer and I'm also currently translating CC, can I ask you what you thought about 'render to file' just from looking at the name? And what would you call the tool instead? Just asking, if you don't mind of course...
Kwanmok
Post by Kwanmok »
Render to file sounded as if it would save cloud details in a text file rather then capturing an image.
I would actually use the term 'capture figure (or image)' or' export image'.
Best,
Kwan
Oiz
Post by Oiz »
Ok! thanks for your answer and suggestions :)
