Would you consider adding a checkbox to allow for automatic export of a segmentation polyline?
I end up saving all my polylines by hand as I need to go back and forth with re-using them for posterior reprocessing.
(I segment my poingclouds, to subsample different areas at different levels, and then merge them back, to mesh without holes, then I re-use the same polylines to segment the meshes for posterior processing outside of CC).
Thanks for all the hard work, much appreciated.
