coordinate transformation
Posted: Tue May 07, 2019 1:00 pm
by anastasijaarsova
Hey guys
i have the following problem
i have point cloud where the station point coordinates are switched(X is written instead of Y and Y instead of X north). So the point cloud is misplaced. Is there any way to transform the coordinates?
Re: coordinate transformation
Posted: Tue May 07, 2019 8:34 pm
If it's an ASCII point cloud, then it's very simple to swap the column roles at loading time so as to change that.
Otherwise, you'll have to use the 'Edit > Apply transformation' matrix and provide a matrix that swaps the dimensions.
For your example (swapping X and Y), it will look like this:
0 1 0 0 0
1 0 0 0 0
0 0 1 0 0
0 0 0 0 1
