e57 to xyz
Mat
e57 to xyz
Post by Mat »
Im a a new user and I can´t figure out how to convert a .e57 (or .pts) file to an .xyz file. When I open the file I don´t have the option to save the file or convert it.
I´m reading the documentation but cannot find any solution. There is obviously something that I´m missing on how to use the software...
Thanks in advance!
Re: e57 to xyz
Load the file. Then highlight the cloud (and not the group with the filename that contains the cloud(s)).
Then 'File > Save' will let you choose the ASCII format and the output filename.
Mat
Re: e57 to xyz
Post by Mat »
Thanks a lot for your answer and sorry for the dumb question! I realized I had to select my file on the left part and then save it.
I managed to convert a .rcp into ASCII and read it with SolidWorks, wonderful job and thanks to the developpers!
Regards,
