Polyline from point coordinates
Cuccio
Post by Cuccio »
Hello Everyone,
I was wondering to create a polyline by connecting points with known coordinates X,Y,Z. Is it possible?
Thank you very much in advance for your help!
Re: Polyline from point coordinates
Yes, either you load these points and then select them one by one with the 'Point List Picking' tool (you can export the selection as a 'polyline').
Another option is to save these points in ASCII/text format (one point - X Y Z - per line) and use the 'poly' extension for the file. CC will load it as a polyline.
Cuccio
Post by Cuccio »
Thank you very much! It works!
