M3C2 Rasterization
Posted: Thu Aug 15, 2019 3:01 pm
by Lewis Ahearne
I'm working with an M3C2 file output and attempting to rasterize the scalar field, the documentation for rasterizing suggests that any scalar field can be used for the raster but it says "invalid layer?!" when I try.
On a related note, when using M3C2 via the command line, I can't get it to use the first cloud as the place to take core points from, I've tried loading and saving various parameter files, but changing this option makes no difference to the files at all and they only appear to be able to sub-sample the original cloud.
Re: M3C2 Rasterization
Posted: Fri Aug 16, 2019 1:58 pm
Which version are you using? Because I believe this bug has been fixed recently (you should try the 2.11 version).
Posted: Fri Aug 16, 2019 3:10 pm
by Lewis Ahearne
That might be the issue thanks! Is this a fix for both of the issues or just the M3C2 computation?
Posted: Fri Aug 16, 2019 3:44 pm
Oh sorry it was at least for the 1st issue. Not sure about the second one ;)
