Command line mode -> 2.5D quadratic Fit
Giraldine_MED
Post by Giraldine_MED »
Hello everyone!
I discovered CloudCompared a few months ago and it really helps me in my projects so far.
I would like to automatize the analysis that I do on point clouds, but for now, the 2.5D quadratic functionality (https://www.cloudcompare.org/doc/wiki/i ... it_Quadric) is not implemented to use in command line mode.
I found the ccQuadric Class definition (https://github.com/CloudCompare/CloudCo ... uadric.cpp) and I supposed that could be implemented in the CommandLine command procedure as it is for the ccPlane Class, but I have no idea how to do it myself..
Is someone has already done it?
Thanks for your collaboration!
Marie-Eve
Re: Command line mode -> 2.5D quadratic Fit
Oups, I missed your post...
I believe no one has implemented it yet, but it would be quite easy to implement the Quadric fit via the command line. You could simply copy the behavior of the 'Fit plane' option (-BEST_FIT_PLANE):
https://github.com/CloudCompare/CloudCo ... .cpp#L1913
And you can also mimic the way the 'Quadric fit' method is called in the MainWindow class:
https://github.com/CloudCompare/CloudCo ... .cpp#L4650
Giraldine_MED
I missed your answer..
Thanks, I will try it.
Milly
Post by Milly »
Hey all,
I need the 2.5D quadratic Fit tool too. I dont find it in commandline Readme.
My question is if the tool has been implemented into the commandline tool or if this has not been done yet.
Thanks for helping me out.
I don't think it has been implemented yet.
Milly
Post by Milly »
Okay Thanks for yor fast answer
I will implement it. How can I send you my Solution?
And Thanks for the entire Projekt !!
WargodHernandez
Post by WargodHernandez »
Milly wrote: Wed Apr 21, 2021 2:16 pm Okay Thanks for yor fast answer
Easiest is submitting a pull request on Git https://github.com/CloudCompare/CloudCompare/pulls
