Error PDAL exception
Posted: Thu Aug 20, 2020 1:06 pm
by AndreasB
I'm having trouble reading a laz file downloaded from a website.
Whenever I try to open the file, I get this error:
PDAL exception: readers.las:reading point 266114 of 2661600 total points.
An error occured while loading 'las'' : the third-party library in charge of saving/loading the file has failed to perform the operation.
I searched the forum and this questions was posted before but with no further answer on how to solve this.
thanks in advance,
Andreas
Re: Error PDAL exception
Posted: Thu Aug 20, 2020 8:49 pm
Which version of CloudCompare did you use?
And if you are on Windows, can you try with the other LAS file filter? ("LAS 1.3 or 1.4")
Posted: Fri Aug 21, 2020 12:58 pm
by AndreasB
I'm currently on version 2.11.1.
How do I apply these other filters ? I don't see them when I import the laz file.
Posted: Fri Aug 21, 2020 7:57 pm
You have to use the good old "Load dialog" (File > Load). Filters appear as the list (in the bottom part).
Posted: Mon Aug 24, 2020 3:11 pm
by AndreasB
Thanks! the oldschool way, was the way to go!
