Linking CCCoreLib with CoudCompare
All about Windows versions
sviseur
Post by sviseur »
I have downloaded the CCCoreLib-master.zip and cloudcompare-master.zip recent packages from CloudCompare github.
I have installed them within the same directory.
I work on Windows 7 with CMake 3.20.0-rc2 and Visual Studio 2019.
I had no issue to compile CCCoreLib, but when I have tried to compile CloudCompare, its dependency with CCCoreLib failed.
I thought that the dependency between CloudCompare and CCCoreLib was embedded into the CMakeLists.txt of the directory :
CloudCompare\libs\qCC_db\extern\CCCoreLib
However, it seems I have lacked something...
Do we have to set CCCoreLib in a special directory of CloudCompare tree? Do we have to set the CCCoreLib path into any kind of environment variable?
Thanks in advance for your help!
Sophie.
Re: Linking CCCoreLib with CoudCompare
Yes, CCCoreLib is a submodule. You shouldn't have to download the zip file, but simply "update/pull" the submodule (git submodule update --init --recursive)
sviseur
Post by sviseur »
Dear Daniel,
Many thanks!
I thought it was possible to install appart from a github platform!
Ok! I install "github desktop" and it works perfectly!
Best regards,
Sophie.
