CC and Nvidia M4000
Posted: Mon Sep 13, 2021 8:55 am
Thank you for sharing and maintaining this amazing software.
I have installed CC on a decent workstation (DELL Precision Tower 5810) having Xeon 1630 V3 CPU Nvidia M4000 GPU with the latest drivers installed (at least for the GPU)
When I start CC I get this:
"[16:45:34] CloudCompare started!
[16:45:35] [3D View 1] Graphics card manufacturer: NVIDIA Corporation
[16:45:35] [3D View 1] Renderer: Quadro M4000/PCIe/SSE2
[16:45:35] [3D View 1] GL version: 4.5.0 NVIDIA 376.84
[16:45:35] [3D View 1] GLSL Version: 4.50 NVIDIA
[16:45:35] [3D View 1] VBOs available
[16:45:35] [3D View 1] Shaders available
[16:45:35] [3D View 1] GL filters available
[16:45:35] [3D View 1] Color ramp shader loaded successfully
[16:45:35] [3D View 1] Stereo mode: not supported
[16:45:35] [ccGLWindow] 3D view initialized
[16:45:35] [Global Shift] Max abs. coord = 1e+4 / max abs. diag = 1e+6"
...and all looks good
The problem I have is that when I open a max 2 Gb Point cloud as *.e57 aggregated in Faro Scene, and from a Faro scanner It loads pretty slow ana when I try to use the cut tool the CC freezes or closes or respond very very slow, depending on the moment. For example, with merged point cloud selected, when I select the cut tool, the icons of the menu appear after ~3 min and if I can make the selection without crashing, the action completes after more than 10 minutes and this behavior indicate the somewhere something is "choked"
Did anyone experience such behavior? There is a way to identify where the problem is and to fix it?
In task manager, I get only "not responding" for CC.
Thank you,
Bogdan
Thank you,
Bogdan
