Why are surfaces created even where there is no point cloud?
Posted: Tue Feb 01, 2022 11:40 am
by ken@67
When I applied Poisson Surface Reconstruction, the surface are created even where there is no point.
The black area shows point clouds.
Why the surface converges to a rounded shape?
Could you recommend an article or where should I get the theoretical guide?
Re: Why are surfaces created even where there is no point cloud?
Posted: Tue Feb 01, 2022 3:49 pm
Yes, the Poisson Surface Reconstruction algorithm creates a closed and continuous surface by default.
But there's a way to clean that afterwards: see the documentation: https://www.cloudcompare.org/doc/wiki/i ... n_(plugin) (especially the "Using the output density" section).
