Box orientation parameters in XML for Cross Section
Posted: Wed Sep 21, 2022 8:36 am
by Darius_bd
Hi!
Does anyone knows if it's possible to set the Box Orientation when defining a Cross Section via XML? The example file just mentions Box Size and Box Center.
Thanks!
Re: Box orientation parameters in XML for Cross Section
Posted: Thu Sep 22, 2022 5:38 pm
There's no way to set the box orientation. But you can maybe apply a transformation to the cloud/entity before extracting the cross section, and then apply the inverse transformation?
All that with -APPLY_TRANS, the issue being that you need to pre-compute the transformations and store them in 2 separate files...
Posted: Mon Sep 26, 2022 11:38 am
by Darius_bd
Hei, that's a good idea! Thanks for the help Daniel
