ASCII EXPORT - Only X,Y,Z
Posted: Fri Dec 16, 2022 3:47 pm
Would it be possible to add an ASCII EXPORT option to export only ASCII "XYZ" variables?
This is for import into software that only uses those 3 variables (like Engineering software).
With the current ASCII Export, I have to take the output file, break it into smaller files that Excel will accept (even the current version is limited to 1 million points), then cull the other variables so only XYZ remains. Then rejoin all the files to create a single XYZ for import.
It'd be GREATLY appreciated... :)
Thanks for listening...
JoeK
JoeK
