BIM Level of Accuracy in 95% confidence interval
Posted: Wed Feb 22, 2023 2:31 pm
by Joel
Hello all,
when comparing two point clouds using the "compute cloud/cloud distance" function, you can have the normally distributed standard deviation calculated afterwards using the "distributions fitting" function.
Is there also a function that calculates the 2Sigma standard deviation within 95% confidence?? For example to calculate the level of accuracy for BIM applications?
Re: BIM Level of Accuracy in 95% confidence interval
Posted: Thu Feb 23, 2023 10:01 pm
Hum, I guess it's not simply twice the standard deviation then?
Posted: Fri Feb 24, 2023 8:47 pm
by Joel
Thanks you're right.
Maybe i should refresh my statistic knowledge...
