Transform Raster grid into vertical cross-section
Posted: Tue May 23, 2023 8:52 pm
by Jeremie
I have some raster images (.bmp) representing seismic cross-sections. When I import them in CC as RASTERgrid format I can manipulate them in 3D, however I would like to swap axis as the images represent vertical cross section and not horizontal surface. I couldn't manage to make the transformation in CC. Is it feasible or am I missing something ? Thank you, Jérémie.
Re: Transform Raster grid into vertical cross-section
Posted: Sat May 27, 2023 9:43 am
You can simply use 'Edit > Multiply/scale' and set a scale of '-1' on the dimension you want to flip.
