Cloud to cloud distance
simplest
Post by simplest »
in what units is this represented ?
maybe im blind but i dont see anywhere in program after computing cloud/cloud distance or within M3C2 method
is this in meters, centimeters or what? there are only numbers there
(ok bellow angle part it says degrees - but other than that - i dont see it anywhere)
Thank you in advance!
Re: Cloud to cloud distance
Ah ah, I can't count the number of times this question was asked.
CC is 'unit agnostic'. It reads the coordinates as they are stored in the file. It simply uses the coordinates as is, hence distances or similar values will be expressed in the same (implicit) units. The user should generally be able to determine the units. Anyway, the units are almost never specified in most of the file formats. So CC has no way to know that.
