Error: 'the third-party library in charge of saving/loading the file has thrown an exception'
Posted: Tue Aug 29, 2023 3:32 pm
I received an .e57 file and when I try to open it in Cloud compare, I get the following error:
"An error occurred while loading '[filename]': the third-party library in charge of saving/loading the file has thrown an exception"
I know the scan was done on a Lecia 3D scanner and processed in Cyclone Register. I was provided the .e57 file along with a .CRS and .LIB file. I was reading some of the posts and there were comments about having a special character in the name (such as # symbol), and I have no idea how to check for this. I am assuming when it was exported from Cyclone register it was a .las file and then converted to .e57 or there was an error in the export process for the .e57 it self.
Are there any solutions on how to correct this so I can open the file? I have no access to the original/raw data and have to make do with the file I have.
The .e57 file is 1.21 GB and I am using Cloudcompare v2.12.4 (Kyiv)
