Job Done Message
fifty8ch
Job Done Message
Post by fifty8ch »
Hi@all.. is there a way in a batch processing the job message (job done) per command parameter to auto accept or disable it?
Re: Job Done Message
You should simply use -SILENT to avoid this message to appear? (and any other dialog as well)
fifty8ch
Post by fifty8ch »
if i do this...nothing happen. the silent option isnt working for me
fifty8ch
Post by fifty8ch »
Anyone has a soultion or workaround?
What do you mean by "nothing happens"? Have you put the option at the beginning of the command? (after 'CloudCompare')
fifty8ch
Post by fifty8ch »
yes i did.. no operation starts and no log is written. If i started without the silent option, all batch command works
Which version were you using?
