Import normals from scalar field
Posted: Thu Dec 07, 2023 10:08 am
by mariolino
Is it possible to implement this feature?
At present I have to export the cloud in ascii and then re-import it indicating the fields of the normal, it would be much easier if there was this command
Many thanks
Re: Import normals from scalar field
Posted: Fri Dec 08, 2023 9:15 am
Interestingly, I just addded this feature in the latest 2.13.beta version (last Saturday!).
See https://www.cloudcompare.org/doc/wiki/i ... _as_normal
Posted: Sat Dec 09, 2023 12:35 pm
by mariolino
It works correctly, very well!!!
To set scalars as coordinates it would be nice to have the same interface like this, to be able to set three values at the same time (as possible values there should be the current coordinates , I use scalars to give the same cloud other projections).
Many Thanks
Mariolino
