Circle Diameter Measurement
anushka
Post by anushka »
Hi CloudCompare Community,
I have two poincloud data with two circles on it. I am trying to detect the Centre of each circle and also measure the diameter of each circle to compare the dimension on each scan. How can I do it?
Thanks for any help.
Re: Circle Diameter Measurement
Can you easily separate them with the scissors tool?
If yes, then you can simply use the 'Tools > Fit > Circle' method on the 2 separate clouds.
