about intensity
Posted: Thu Jan 18, 2024 6:27 am
by hina
I am doing research using LiDAR to make measurements. What does intensity mean in CloudCompare? Do you mean reflection intensity?
Re: about intensity
Posted: Thu Jan 18, 2024 10:36 am
'intensity' is generally just the name of the scalar field, as it's saved in the input file. CloudCompare doesn't know how each scalar field is generated. It manages scalar fields in a generic way.
Generally it's the laser reflectance, but the units and the post-processing applied to it are not necessarily obvious.
Some formats describe what 'intensity' is in a more precise way. For instance LAS or E57. But in each case you'll have to refer to the specification of these formats (and hope the specifications are respected ;). Manufacturers such as Faro or Riegl also have their own definition of 'intensity' that would apply to their proprietary formats.
