error "Render to File"
Posted: Thu Jun 13, 2024 8:13 am
I think there is a problem with the graphic scale that is generated when the "Render to File" command is executed.
I am obtaining vertical sections of a model and when saving the frontal capture I do not get a scale elevation. In the image obtained, the measurement that appears is exactly 25% larger than the corresponding one (for 4 m a graphic scale of 5 m appears, and for 8 m it appears 10 m), do you know if there is any error?
CloudCompare Kharkiv version 2.13.1
