Collapse Label
Posted: Tue Aug 06, 2024 8:17 pm
by dcobra
I used to be able to right click on a label to collapse it and only see the title. This doesn't appear to be working anymore. Is there another shortcut key?
Best,
Cody
Re: Collapse Label
Posted: Fri Aug 09, 2024 6:45 am
It should still work (at least in the 2.13.2 version). Which version / setup are you using?
Re: Collapse Label
Posted: Fri Aug 09, 2024 11:19 am
by dcobra
I'm using 12.13.2 on windows 10. I tried it on another computer running the same version and it works. Not sure why it works on one machine and not the other.
Re: Collapse Label
Posted: Sat Aug 10, 2024 7:43 pm
Maybe a screen resolution or a graphic driver issue, hard to guess...
