[Fixed] properties windows GONE
Posted: Fri May 02, 2014 7:34 pm
by p01ntsurf3r
ok, i have re-installed CC multiple times, each time i have deleted any residual directories, but when i re install i cannot access the properties pane. i right click on the menu pars and there is the option to show it, however its gray and i cannot select it to enable it no matter what i do. is there a registry key that i need to delete to set this back to default settings. i don't understand why i am not allowed to use the properties window. it is the most annoying thing ever considering i can use CC fine on a dozen other computers accept for the one that has all the processing power. ugh
Re: properties windows GONE
Posted: Fri May 02, 2014 7:40 pm
by p01ntsurf3r
well i fixed it by removing the first cloudcompare registry folder when i searched the registry. there was some stuff about windowgeometry in there. after deleting the entry cloud compare properties window is now displayed....i recomend a RESET option that resets ANYTHING cloudcompare has put in the registry....this stuff was obviously not removed eachtime i reinstalled cloudcompare which has made this issue extremely troubling...when you uninstall something it should remove ALL traces of it to prevent wasted time trouble shooting these issues anyways.
Posted: Mon May 05, 2014 8:32 am
As this is an open source project we'll kindly accept any contribution: don't hesitate to edit the (InnoSetup) installer script to enhance it the way you suggest.
Personally I'm not the one who generated this installer stuff but I was only grateful to its initial contributor ;)
Posted: Fri Jun 20, 2014 8:43 am
For the records a "Reset all GUI elements positions" method has been introduced in the to-be-released version of CC (2.5.5).
