about M3C2 algorithm
I want to kown what is the unit in the M3C2 algorithm,such as distance,normal scale and projection scale.Is it meter or milimeter?
Re: about M3C2 algorithm
As for CloudCompare, it's the same units as your cloud coordinates (what we call implicit units).
Black points? Can you share a screenshot with us?
If you have only black points, it's maybe that the "color scale" shader doesn't work on your machine. You can try to deactivate it in the "Display parameters" (menu "Display > Display settings"). Open the "Color scale (scalar field)" tab and uncheck the "Enable shader for faster display (...)" option. Restart CC just to be sure.
